I have seen several references to this "Rule" about RaidZ stripe width. The "Rule" goes as follows:
(n^2+p) drives for RAIDZ sets, where n is a number and P is the RAIDZ level.
OR
(N+P) with P = 1 (raidz), 2 (raidz2), or 3 (raidz3) and N equals 2, 4, or 8
So,
RAIDZ 3, 5, or 9 drives
RAIDZ2 4, 6, or 10 drives
RAIDZ3 5, 7, 11 drives
Sources:
https://forums.freenas.org/index.php?threads/getting-the-most-out-of-zfs-pools.16/#post-52
https://forums.freenas.org/index.php?threads/getting-the-most-out-of-zfs-pools.16/#post-2043
http://www.solarisinternals.com/wik...onfiguration_Requirements_and_Recommendations
https://forums.freenas.org/index.php?threads/raid-z1-4-drives-bad.6066/#post-22273
https://forums.freenas.org/index.php?threads/raid-z1-4-drives-bad.6066/#post-22216
You'll notice that link is dead, but I found a PDF version of it from 2010 here: https://documents.irf.se/get_document.php?group=Computer&docid=311. If you scroll to page 6, you'll see where this idea comes from, and a link of where whoever wrote this now-missing document (maybe) got the idea, but that link is also broken. If you do more internet detective work, you'll find a copy of that blog post (from 2008) here: https://blogs.oracle.com/timthomas/entry/recipe_for_a_zfs_raid
There is also dissent about this:
https://forums.freenas.org/index.php?threads/raid-z1-4-drives-bad.6066/#post-22275
My question is: Has anyone actually done benchmarks on this or tested it at all to see if there is any real world truth to it? I see no mention of it in the ZFS docs from Oracle. I also haven't seen any actual math backing it up.
OR
So,
Sources:
