I tried to move the System dataset to my secondary pool, because it prevents the disk in the primary pool to spindown (I hope that is the reason). I changed the location of the System dataset in the system settings. That created a .system folder on the secondary pool, but it did NOT create a seprate dataset. Addionaly the .system dataset on my first pool was not removed!
Can I just delete the old dadaset on the primary pool? Is there something I should do, to create the dataset on the secondary pool? I tried to restart the system, without luck!
The build I run is: FreeNAS-9.2.1.3-RELEASE-x64 (dc0c46b)
EDIT:
I tried to update to the newest release and now I run the follow build: FreeNAS-9.2.1.7-RELEASE-x64 (fdbe9a0)
I also realized, that my secondary pool is just a UFS device, that explains the missing datasets (shame on me!)
The gui stopped showing a .system dataset on my primary pool witht he update, but using "zfs list" there are still 4 datasets related to .system and subfolders!
Is it possible to use a UFS device for the system dataset (no errors in gui...!) can I just delete the .system datasets using command line?
EDIT:
