sboutros
 - Sep 8, 2017
I have TrueNAS-13.0-U5.3 running on a Dell R710.
All running fine.
I have a 5T external USB drive with 2 partitions (with existing data on each partition).
1 partition is FAT and the other is Ext3
I would like to mount both partitions for R/W access.
I have tried via GUI and via command line.
Via GUI: Storage->Import Disks - resulting in rsync failures (err codes: 10 & 11).
Via Cmd:
mount -t msdofs /dev/da7p1 /mnt/sea_fat
mount: /dev/da7p1: Operation not supported by device
mount /dev/da7p1 /mnt/sea_fat
mount: /dev/da7p1: No such file or directory
I assume what I am trying to do should be supported to an extent based on what the GUI implies.
Just wondering why both approaches fail.
			All running fine.
Via Cmd:
