Mixed Disk capacities and strange display of Disks / Status after resilver
jackydany
Hi there,
my config:
Truenas Scale 22.12.1
Dell R620
128gb Ram
3 Pools, 2 are used
The used Pools are RaidZ3
Pools out of Netapp DS with 2x 12 4tb HDDs SAS
I had a disk failure on one of the pools.
Truenas took the disk offline, fine because of RaidZ3
So i pulled the disk from the Netapp Diskshelf and replaced it with a different SAS drive.
Replaced the disk via WebUI.
It started resilvering. It already showed a message regarding mixed capacitiy, even though it just started to resilver.
During resilvering, the disk showed write errors and read errors as well.
So i pulled the "same" disk again and replaced it via WebUI again.
This time the resilver went straight on and showed no errors.
But now i have several behaviours that confuse me quite a bit.
1. the pool shows Online, No Disks with erros, topology green checked but a Mixed disk capacities.....
2. if i click on storage, pool status for this pool, then manage devices, i expand the raidz3 tree and see one deivce without disk symbokl in front.
i have twelve disks online, no errors but one disk is missing the symbol. if i select this disk, it states: Disk Info: Disk in unavailable.......
3. i cant start a manual smart test, because the disk is unavailable.
Could anyone help me to figure out why everything seems to be fine, no errors, but there should be a disk missing?
state: ONLINE
  scan: resilvered 2.97T in 1 days 12:22:05 with 0 errors on Wed Apr 26 00:22:22 2023
        NAME                                      STATE     READ WRITE CKSUM
        Tiger                                     ONLINE       0     0     0
          raidz3-0                                ONLINE       0     0     0
            38cfd181-08db-11ec-90c3-90b11c022d72  ONLINE       0     0     0
            39ca4c4f-08db-11ec-90c3-90b11c022d72  ONLINE       0     0     0
            3aeaf0d3-08db-11ec-90c3-90b11c022d72  ONLINE       0     0     0
            3b9eeecb-08db-11ec-90c3-90b11c022d72  ONLINE       0     0     0
            3bc174e0-08db-11ec-90c3-90b11c022d72  ONLINE       0     0     0
            3d3f5733-08db-11ec-90c3-90b11c022d72  ONLINE       0     0     0
            3cd8670b-08db-11ec-90c3-90b11c022d72  ONLINE       0     0     0
            79711dff-97fe-4e78-b97f-aa438e92e49d  ONLINE       0     0     0
            2b0c9b00-71fb-11ec-b840-90b11c022d72  ONLINE       0     0     0
            3df6532d-08db-11ec-90c3-90b11c022d72  ONLINE       0     0     0
            3e145435-08db-11ec-90c3-90b11c022d72  ONLINE       0     0     0
            3e2f1fe3-08db-11ec-90c3-90b11c022d72  ONLINE       0     0     0
Thanks a lot
Your zpool status doesn't show disk capacities, so I can only comment that your pool is online and healthy according to that.
A screenshot of that might be helpful. Sounds a little odd, but with zpool status showing all clear, I'd normally trust that better than the GUI.
smartctl -t long /dev/daX (change daX to your disk identifier)
smartctl -a /dev/daX when done to see the results/progress
jackydany
Thanks for the reply.
Device sdp isnt in the disk list.
So i dontknow what is happening here :D
Maybereboot the Server? Wouldnt be that big of an issue.
jackydany
Ok, i had to resilver another disk from the other pool.
after this, irecognized, that there was the mixed disk capacities message as well.
and... i had 2 unassigned disks which could not be true.
so i rebooted.... that fixed it. no unassigned disks, no mixed capacities anymore, all disks are showing the disk symbol and all disks are present.
seems like a little bug in the UI not gathering all informations correctly.
