MiniDLNA not sharing media data with control points
davide256
Just installed FeeNAS to trial as a DLNA/UPNP server. Plex works but MiniDLNA is a problem. I can see the media files directory structure in the MiniDLNA jail media directory but trying to access MiniDLNA via any UPNP control point only shows the default MiniDLNA categories, no file data underneath. What am I missing? Please keep in mind that I know little about Unix/Linux, am used to DOS/Windows. Freenas version is FreeNAS-9.2.1.7-RELEASE-x64 8gb memory
joeschmuck
Old Man
Odds are you either setup the MiniDLNA configuration incorrectly or didn't add shares. The other possibility is the file format is not correct for the device you are viewing with. Hopefully by now you were able to figure this out.
