hungarianhc
- Mar 11, 2014
I currently have a Raid-Z2 array of 5 4TB disks, and it is starting to fill up. I'd like to replace it with a new Raid-Z2 array of 4x10TB. I have plenty of SATA ports...
The most common recommendation I have seen is to create a new pool and use zfs send / receive to replicate the data. If that's my only option, that's fine, but there's some manual work there, and then I'll need to clean up all of my shares to point to the new pool instead. Is there a way to just have two vdevs in FreeNAS, use the UI, and tell it to "move" the pool from one to another? Then it resilvers, and I'm done? Or is the zfs send / receive option the best? Thanks!
