jdownloader 2 plugin - invalid directory on mount point
Alister
I've installed the jdownloader plugin
I have a mount point
/mnt/test -> /mbt/Big/Huge/test
from shell of plugin
touch /mnt/test/test.txt
creates a file
/mnt/Big/Huge/test.txt
proving that modify permission is working
When I se jd2 to use /mnt/test as directory it fails with "invalid directory" but /usr/local/jdownloader works
Alister
Using shell
I found that the jdownloader user is not a member of wheel, adding to wheel has fixed the issue
pw group mod wheel -m jdownloader
Not good long term, but it works for now
directory permissions on /mnt are
root@Jd-plugin:/mnt # ls -lA
total 162
drwxrwxrwx+ 30 root wheel 53 Aug 28 11:35 Huge
drwxrwxr-x+ 111 1001 wheel 176 Aug 30 21:09 test
drwxrwxr-x+ 2 1001 wheel 2 Aug 17 23:02 test-s
Alister
And it's stopped working
I'm going to try putting
in /etc/rc
and see what happens
I can't find who created the plugin though
ans
alister,
Have you been able to figure this out? I am having the same problem.
Alister
put the pw command in /etc/rc got it working
ans
Thanks, I will have to somehow figure out how to do that. I am new to all of this.
Alister
WebUI -> Jails -> expand Jd-plugin -> shell
you'll need nano as it's a simpler editor
pkg install nano
dotbanana
I have the same problem as the thread starter with the jdownloader-plugin.
Permissions in the mounted folder are okay, i can touch and create folders, but jdownloader shows 'Invalid download directory'.
Unfortunately the command
does nothing for me in this regards.
It's the standard plugin-jail, i have not changed anything.
dotbanana
I figured a way out to make it work:
Jails -> jdownloader -> Mount Points -> Three points next to mount point -> Edit ACL -> Scroll down and add ACL item
Who: Group
Group: wheel (use the dropdown)
All the other things default
-> Save
ans
alister, I got that installed. not sure what to do from their.
dotbanana, that didn't work for me.
