I recently upgraded my router and upon doing so, I can no longer get my Plex jail to run. Previously, I had to set a static IP as the DHCP option never seemed to work for some reason. But now I can't seem to get either a DHCP or Static configuration to work.
When I tried to edit the Jail configuration I get the error:
HTTPSConnectionPool(host='www.freebsd.org', port=443): Max retries exceeded with url: /security/unsupported.html (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 65] No route to host'))
then when I try to start the Jail I get:
Error: [EFAULT] No default interface found
The Jail does start up though -- it's just not accessible (by ping or by web portal)
I have already gone into Network > Global Configuration and set the DNS and Default Gateway.
I'm wondering if something is being blocked with the new router as when I switch back to the old router it does work again.
EDIT: I'm running TrueNAS 12 U8
