Hello TrueNAS... I'm new to the forum, but I've been lurking for awhile. I've been accumulating parts for the better part of a year, and I'm just about ready to build. I just am seeking some advice on use of SSD/NVMe disks.
If you see my signature, you'll see I've got five 16TB Ironwolf Pro drives, which I plan to use in a RAIDZ2. Despite the slightly awkward geometry, I've read plenty of forum posts that suggest this config works just fine....so I'm not too worried about that. I'm worried about the other stuff....
There's the boot drive, for the OS....there's ZFS metadata, there ZFS logs, there's L2ARC, and maybe other things I'm not familiar with. Right now I just have a single 1TB M.2 Samsung 990 NVMe drive. 1.5 Million MTBF. Is this good enough for all those? Should I forego L2ARC until doing some testing with the 64GB RAM utilization? Should I get a separate SSD just for the boot drive, and separate out the ZFS metadata/logs/etc?
Truthfully I'm pretty good at building systems....I'm just new to ZFS and spec'ing hardware for ZFS.....so I'm seeking advice on how to use my hardware to optimize ZFS according to best practices!
Cheers,
Jon
Cheers,
Jon
