Installing a Distributed MINIO 1.6.41 on Scale 22.2.2.1
mtindall1
Has anyone got a detailed install process for installing a distributed MINIO on Scale 22.2.2.1?? The current link and process does NOT reflect the current version on Scale. Trying to work 3 nodes into this.
I am working with the charts native MINIO version 1.6.41 which is different than the version used in the scale documentation.
morganL
Captain Morgan
Administrator
I think you'll need 4 nodes (2+2EC).. we've only tested with the approach in the scale documentation.
mtindall1
I have 4 nodes up. Minio goes active on all 4 but web portal not accessible. Log from container say its waiting on some disks and also says file permission errors.
Using the latest minio and latest scale.
mtindall1
Did you use the official App or a docker container?
Did you follow the documentation?
yes, and unfortunately its not applicable to current versions nor is it complete. Was hoping there was a better set of instructions that applies to the current versions. I have tried so many different iterations and cant get it working.
whats funny is I can get it to work just fine on a single server, but it wont work when distributed. I have tried several different times. I have 4 servers, I have put exactly whats in the instructions and it wont even go active. I have changed it up and moved things around to get it to go active but logs show more errors and the console wont even load.
