I read and re-read many topics and now need to decide. Basically, I'm trying to see what is going to be a most balanced solutions in terms of power, energy efficiency and initial cost.
I'm also thinking that I will use this new build for at least 5+ years, probably 10 or so. So, in my calculations I like to use $1/W/year just to make it easy. 20w vs 50w CPU will equal $30 per year in energy savings. And I want to calculate it over 3-5 years. Basically, if I can build system that's 60W more efficient - that will save roughly $180 which means I can put this money upfront.. So, thats my math. Now to constraints:
1. It's home NAS, will be used maybe 8-10hr per day. There will be no crazy jails. Maybe PLEX. Maybe. And it will not transcode more than 1 stream at a time. Look at CPU I have now (in my signature) - it's plenty..
2. I already have CASE, so the build is somewhat going to be around this case. It's SuperMicro 846 chassis with SAS2 backplane and 2x1200 GOLD PSU. I am aware (and I read this big topic about PSU and studd) about PSU efficiency, I may or may not go with smaller wattage platinum PSU. I will test how much fans using by pulling them, etc.
Main decision is between MB/CPU combos:
Initially I was thinking X10 board. If I understand correctly this setup will cost me $250 + $60 for G32220 CPU. It has SAS on board. And it will give me huge convenience in cabling. I can hook up 1 cable to backplance to handle all the drives.
But then I read a little about Atoms. What is good about them? How much more efficient they are? Can I install this small board in my case? I know supermicro also makes those, why not listed and wny Asrock?
Cost seem to be $400 for board with CPU. But then I need another $100 for LSI card, correct? So, cost is like $190 over X10. Will it save this money over 3 years?
Basically, I want you to tell me how much better Atom-based system will be. I'm sure my useage totally permit's such board. I'm just not sure which way to go right now with a build.
- Supermicro X10s (32GB of RAM max)
- The X10SL7-F ($240) is amazing if you are planning to go with more than 6-8 disks but don't want the cost jump with going beyond 32GB of RAM. It has a built-in LSI SAS 6Gbps controller which you can reflash to IT mode fairly easily which saves you from the mess of buying an M1015 and using it as an add-on card (not to mention the cost savings). On-board gives some small performance gains and this is a clear choice if you are looking for a good long-term system that is highly expandable. It has IPMI, dual Intel Gb LAN, lots of SATA and SAS and is a proven winner for many users in the forum. This is the current winner for those that are looking for that ultimately expandable server for home use.
- Intel Atoms (Avoton generation)
- The new Intel Atoms kick butt. They use ECC RAM and can be loaded with 64GB of RAM if you buy special 16GB UDIMMs.
- The Asrock C2750D4I ($250-300 but sometimes as high as $400) is pretty popular. The Marvell SATA ports have been known to be problematic for some people but the mainboard has built-in IPMI, 6 SATA ports on Intel SATA, dual Intel Gb LAN and has a single 8x PCIe 2.0 slot for expansion. This CPU has 8 cores (no hyperthreading) and seems to be very powerful despite its size. It is capable of doing transcoding of video streams with Plex and is the board found in the FreeNAS Mini. A review of what this board can do is available at Cyberjock's Blog. A 4-core version exists, the C2550D4I and is slightly less expensive for those looking to save a little money with a less powerful box.
