If I use raidZ2, I will lose three disks of space
bigfly
12x8T(7.28) raidz 11X7.28=80.08
When I create it successfully, the storage space is only 75.15T
More exaggerated If I use raidZ2, I will lose three disks of space
12x8T(7.28) raidz 10X7.28=72.8
When I create it successfully, the storage space is only 64T
why?
kherr
An rz1 with 12 disks isn't all that good of an idea .......
https://wintelguy.com/zfs-calc.pl and play with the #'s, there's various ZFS overhead to consider.
With a convectional raid array you take the # total disks less redundant # of drives times "advertised" size times .9 to get an approximation. ZFS has less than that. the calculator will tell all.
Constantin
Vampire Pig
Besides whatever parity losses there are, ZFS pools also should not be filled above 80% capacity or ZFS performance will degrade significantly.
For my eight drive Z3 setup, that means 3 drives worth of capacity is lost to parity, and another to the 20% headroom, leaving me with 4 drives worth of data storage capacity.
