How to zero drives using FreeNAS?
Shiroi Kage
I'm about to move and I have to disassemble my box and sell my HDDs. I want to zero them before doing that. How do I do that in FreeNAS? Is it possible at all?
Shiroi Kage
...and if you don't trust the button, 'dd if=/dev/zero of=/dev/ada0 bs=1m' will do the trick.
Thanks!
May I get a little bit more explanation on how this command works? How do I specify which drive(s) will be zeroed by this, or will this just go through everything recursively?
ethereal
/dev/ada0
change this to the drive you want to wipe - obviously be careful you select the correct one.
