How do I upgrade/deploy a new plex server / version.
when I'm on the jail it looks like the upgrade there actually upgrade the jail os and not the application contained or am i missing something.
G
Anything you do in TrueNAS jails depends on the FreeBSD packages, not on anything released by Ubiquiti. If the FreeBSD packages are behind Ubiquiti's releases, the right person to address is the ports maintainter for that particular port, not the TrueNAS community. You can find the email address of the maintainer at the Freshports link.
If you pkg install unifi6 in the current jail, it will most probably uninstall unifi5 automatically, because packages regularly have "conflicts" definitions that tell the system they cannot coexist. If your current jail is the plugin, though, I cannot tell you what that command will do. I don't use the plugins at all for precisely the reason that I want to be able to run pkg upgrade without ill side effects.
When I upgraded to version 6 I just ran pkg delete unifi5 followed by pkg install unifi6 and everything just worked. This was in a standard jail and not a plugin.
... trying to remember how I installed it... somehow can't find my notes, but sure it's just a jail I build and then pkg installed it.
here it goes...
G
Of course not. unifi5 and unifi6 are two different packages. Possibly the Unifi documentation lists additional steps you need to perform after an upgrade from version 5 to version 6.
Curious... did this and when i logged in it still showed a unifi5 version number, but the dashboard changed, did not show any of my previous devices etc, and also for some reason did not allow me to click on any link.
for now I'm deleting 6 and reinstalling 5, and restoring my back (2 days old).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
