How to reinstall qBittorrent on TrueNAS without losing qBittorrent settings
100Stress
I need to save qBittorrent settings (On jails/trueNAS), before reinstalling TrueNAS and I don't want to lose the torrents I have.
Does anyone know how to do this?
Jailer
Not strong, but bad
Your jails won't be touched by a re installation of TrueNAS unless you somehow installed them on the boot device. Save a copy of your system config before you re install and then upload it after the installation.
If you created it manually (pure Jail, not from the "Plugin" catalog), you can also make a backup copy of this folder, found inside the Jail's filesystem:
/var/db/qbittorrent/
The exact folder for those using the "Plugin" might be different.
