How to mount on linux
Nas-dude
I setup freenas because i want to setup a linux and windows share,
i followed all the steps online and i was successful on windows 10 and also mapping it
now on linux, i am having a problem "mapping" or as it's called on linux "mounting"
I already did all the steps, such as pools and sharing path,
I just need to mount it from my linux desktop,
what command do i have to use?
my share path is:
/mnt/SecondHD/DataSetTwo
sudo mount -t smb USER@192.168.1.111:/mnt/SecondHD/DataSetTwo /mnt/media/dataset2
You will have to sub example info for your actual info.
Fredda
From the screenshot it's about NFS. So the command would be
sudo mount -t nfs 192.168.1.111:/mnt/SecondHD/DataSetTwo /mnt/media/dataset2
Yes, true. You might also need nfs-common then.
