how to check for checksum using sha256
plankton99
I know simple question to most.
1) where do I get sha256.exe
2) how do I check the 9.3 upgrade file
3) OR, is there just a checksum value for the 9.3 download somewhere I plug in?
pirateghost
Unintelligible Geek
Huh?
Sha256.exe? What is that?
If you are upgrading, FreeNAS does the check for you from the GUI upgrade
marian78
sha256 can check mannualy for example with Total commander, but it is a shareware file manager.
plankton99
I have version 9.2.1.7 release x64, the FreeNAS does not do the check. show exactly how do i get the checksum value to put it in the field in order to upgrade to 9.3
Thanks in advance.
pirateghost
Unintelligible Geek
Thanks in advance.
When you go to the upgrade button, after uploading the upgrade file it asks you for the sha.
You get the sha from the same place you downloaded the upgrade file....
pirateghost
Unintelligible Geek
  • Screenshot from 2014-12-22 13:35:37.png
pschatz100
Bingo!! Now you know why the checksum is provided.
