SOLVED How start VM from shell or script?
Samuel Tai
You'll need the VM ID of the VM. Run midclt call vm.query | jq to find the ID of the VM. To start the VM, run midclt call vm.start <ID>.
curl --user root:password -X POST -H "Content-Type: application/json" http://freenas.local/api/v2.0/vm/id/30/restart where 30 is the ID of the VM you want to restart/start/stop/poweroff/shutdown.
You can find the ID by doing this:
curl --user root:password -X GET -H "Content-Type: application/json" http://freenas.local/api/v2.0/vm
Of course you can find the example here:
including many different scripting/programming language examples.
Or @Samuel Tai 's example works too if you're running the script locally.
blanchet
This is a script to start VM by name
#!/usr/local/bin/bash
# start VM by name
# platform: TrueNAS-12
PATH=/bin:/usr/bin:/usr/local/bin
if [ $# -eq 0 ] ; then
    echo "Syntax: `basename $0` vmname"
    exit 0
fi
# get VM name
VMNAME=$1
# get VM ID
ID=`midclt call vm.query |
     jq --raw-output '[.[] | { (.name): .id } ]' |
     grep $VMNAME |
     sed 's/.*\:\(.*\)/\1/'`
echo "Start '$VMNAME': id=$ID"
midclt call vm.start $ID
