How do I find out why a RSync task is failing?
Tony Self
I have a RSync that is set up to copy files from my UK server to my Thai server. Usually this proceeds without a problem, but occasionally the task fails mid transfer probably due to a temporary connectivity issue.
When I try to manually restart the task it continually fails, even though I am connected to the UK server remotely so there obviously isn't a connectivity issue at the time.
Where can I find out why the task continues to fail?
Is the rsync job working with IP addresses or DNS names?
Tony Self
The push rsync job on my UK server is using a DNS name. However the receiving service on my Thai server uses an IP address to filter the incoming connection.
As I said generally the job works without a problem, but there are the odd occasions where a session gets interrupted that it is difficult to restart the job. All I seem to get is a failed alert. What I am after is more detail as to why the restarts are failing so I can resolve the problem and get the job restarted more quickly.
As it happens the job has now restarted and completed. But I do want to know why I couldn't restart the job earlier. There must be some log file somewhere which will give me a bit more information. Or perhaps I need to add an additional option to the job so it will give a more verbose reason for failing rather than a simple "FAILED"
Regards
Tony Self
I was anticipating a potential problem with DNS following an IP cut... I agree that's not great error reporting, so hard to say what's going on.
Have a look for recently changed files under /var/log
Tony Self
Having posted my earlier reply, but then having thought further on your question, I think I have realised what the problem is.
As I said the Push Rsync job uses a DNS name, mainly because I have a dynamic IP address on my Thai server. If the Rsync connection goes down because of a power cut at my Thai location (a not uncommon event) then my ISP will assign a new IP address which will take a little while for NOIP.com to propagate, hence the initial failures to re-establish a connection because it won't be using the newly assigned IP address.
I mustn't put off getting a fixed IP address any longer.
Regards
Tony Self
