danzg
- Jun 18, 2011
Is a "hot spare" an extra, attached disk that can automatically take over for a failed disk in the RAID ... ?
If so, how do I set it up properly?
Is it safe to use with FreeNAS 8.2p1? There is a warning in the docs - "Use this option with caution as there is a known bug in the current FreeBSD implementation."
Will the system immediately replace a failed disk without user interaction?
thanks!
thanks!
