High Availability (Failover) in TrueNAS SCALE ?
vn_mnm
Hello everyone,
From what I know, Proxmox runs on KVM and employs a Corosync protocol to run HA ( https://en.wikipedia.org/wiki/Corosync_Cluster_Engine ). Regarding TrueNAS SCALE :
  1. Which HA (Failover) protocol(s) does it use ?
  2. Is it built in the software iso file or something exclusive to iXSystems-built hardwares only ?
Thank you in advance.
morganL
Captain Morgan
Administrator
HA clustering is done v ia glusterfs or Minio
HA (active-passive) is done via iX hardware with CARP protocol.
vn_mnm
Thank you very much for your reply. Is HA active - passive also HA clustering ? If so, then what are the differences between the 2 above versus CARP ?
Thanks again buddy.
morganL
Captain Morgan
Administrator
Thanks again buddy.
HA (Active-passive) has the 2 nodes sharing the same storage... they use CARP to move a Virtual IP address to the active node. If the ZFS storage pool fails, both nodes have lost the data.
HA Clustering is a shared nothing storage model... a whole node and its storage can fail or be taken off-line and the cluster can still serve data.
The data is mirrored or erasure coded across the nodes to protect it.
