Help!! Export Recycle Bin
naando
Good morning people!
I activated the "Export Recycle Bin" in a directory, but I do not find it when I look in the shell.
Is the "recycle" folder created automatically or need to be created in the hand?
I thank the attention.
Thank you.
D
dlavigne
Guest
Were you able to resolve this? If not, have you tried deleting a test file?
anodos
Sambassador
It's a hidden folder ".recycle" and created when you delete items. In general, I prefer to use ZFS snapshots. For instance, `recycle` is non-atomic if it has to cross device boundaries (ZFS datasets). I put in some default configuration changes / fixes to make this work across device boundaries, but best practice for the SMB recycle bin is to not use it if you have nested datasets.
