Randymations
- Aug 7, 2023
This is a part two to my original post as I felt it was appropriate to make a new post considering I had to restart my hardware search. My goals remain unchanged and my intention is this post serves as a sanity check for me. I believe I have accounted for the necessary variables but would like second opinions before I sink a couple thousand into this. I also have some minor additional questions.
The build:
x1
x12
I also plan on asking the seller to add an additional 128 GB of the same RAM to the system.
Alternate option for the system:
Alternate options for the drives:
The questions:
1. Am I missing anything critical?
2. Is it necessary to double the memory of the system? I read that you should have at least 1 GB per TB. If not necessary, how beneficial would it be?
3. Since I plan on running RAIDZ3, I think it makes sense to go for the more computationally powerful system. Is this correct?
4. In many of the systems names, I see something similar to "E5-2620v4". What does this mean? Comparing the specs, it looks like this indicates the specs of the CPU. Is there a guide on what all the different numbers and codes in a SuperMicro server name mean?
Thanks as usual for any and all info
The build:
x1
x12
The questions:
