SOLVED GlusterFS cluster, remove virtual IP after trying SMB cluster mode
Urbaman
I tryied to set up an SMB cluster, now trying to get back to single SMB.
How can I remove the virtual IP added in the process?
Thank you.
Kris Moore
SVP of Engineering
Administrator
Sure! To undo the cluster and go back to single SMB mode, you can do the following:
REVERTING TO NON-CLUSTER MODE on FIRST node:
(Get SMB share and remove clustered share)
# midclt call sharing.smb.query (Get the ‘id’ of the share)
# midclt call sharing.smb.delete 2 (replace ‘2’ with the id of share)
# midclt call service.stop cifs
# midclt call gluster.volume.stop '{"name": "testvol1"}'
# midclt call gluster.volume.delete testvol1 -job
# midclt call ctdb.shared.volume.delete -job
# midclt call service.stop glusterd
# midclt call service.update glusterd '{"enable": false}'
# midclt call smb.reset_smb_ha_mode
# midclt call service.start cifs
REVERTING TO NON-CLUSTER MODE on OTHER nodes:
After doing this and rebooting, you should see those VIPs gone.
Urbaman
First command gives me
Second command gives me
false
Should I continue?
I still have the IP in there after a reboot.
Thank you
Urbaman
Ok, I went through all of the commands even if some of them gave me errors, and the virtual IP disappeared.
Thank you very much,
Kris Moore
SVP of Engineering
Administrator
No problem, glad that helped clear it up!
