General Volume/Disk/Mirror question
mrramsey
Ok I am a little confused but here we go. I installed FreeNAS in a box with 2 x 2TB drives. When I used the wizard I just used the auto setting. I set up the pool called storage-. I am assuming that it set up a raidz1 configuration but I'll be damned if I can figure out where to verify that.
1. Is there somewhere that displays the actual configuration?
2. Is there a way to "view" the data on the mirror to confirm that is actually present?
Everything seems to be working fine but trying to confirm it all.
melloa
Not sure if this is correct, but try:
Click storage on the top -> highlight your volume on that list (1st line I guess) -> click volume status on the bottom. On mine shows raidz2 and that "might" be it. For sure there are other ways from the shell, but I don't want to go there.
BigDave
FreeNAS Enthusiast
It would probably help to know which version you are running.
mrramsey
Thanks, i think that answers part of it. Mine shows:
>storage-
>>mirror-0
ada1p2
ada0p2
Based on that I will assume that Freenas set up the mirror. So now I just need to confirm that the mirror IS actually occurring.
I believe I set things up correctly however just uncertain if there were additional steps to actually set up the mirror. I used another NAS app years ago and recall it had a file browser where I could view the data on disk.
mrramsey
BigDave
FreeNAS Enthusiast
>storage-
>>mirror-0
ada1p2
ada0p2
Based on the output of Volume Status you posted above, you have created a mirror. Unfortunately FreeNAS does not have a built in browser for file views, you will have to set up permissions and shares for that.
FreeNAS has excellent documentation. The manual will be invaluable for getting started with the more basic functions of a storage server and a whole lot more
mrramsey
I have the shares and permissions set up, thats not what I am after. I am specifically looking for a way to verify the data exists on the mirrored drive itself. I have looked through the docs but I am not finding what I am after. My guess is that it is that I am not on the same page with nomenclature.
Both drives show that they are online and I can assume that ada0p2 is the primary drive and ada1p2 is the mirror so in a sense looking to compare the two drives.
SweetAndLow
Sweet'NASty
When you talk about confirming that the data is there what do you expect to confirm? It sounds like you have your share setup and have put stuff there. There isn't anything to confirm if you can see the data in the share.
Neither drive is the main drive. Data gets written to both and read from both.
Your scaring me a little bit because your understanding is very strange. It would be an excellent idea to read some of the threads in my signature. The noob guide is a great starting point.
BigDave
FreeNAS Enthusiast
As far as the OS is concerned, it "sees" the mirror as one drive (as SweetAndLow has correctly stated)
I'm not sure exactly what "proof" or confirmation you are looking for. If your data is backed up elsewhere,
you could remove one of the drives in the mirror and your data should still be accessible. FreeNAS will give a warning
that your pool is "degraded" but the data will be there from the drive that is still online.
mrramsey
Ok I get that it (Freenas) is "seeing" it as one drive. Perfect that is what I would expect in general. What I was meaning was viewing the individual drives singularly, in a sense a compare of the two. i.e there are 5000 files on ada0 and 5000 on ada1.
I have to believe that there is a simple method to compare the two physical drives short of physically removing the drive from the box. That's all I am looking to do. I know that my data is there from viewing in windows explorer but looking to confirm that it is indeed actually being written to both physical drives.
BigDave
FreeNAS Enthusiast
If I understand your need for confirmation, this is available in real time.
From the GUI, go to Reporting > Disk while the machine downloads a file or reads existing files, you should see the activity
for each disk in the Vdev (in your case, a two disk mirror) during the activity as it happens.
SweetAndLow
Sweet'NASty
Verifying the data is being written to both disks is hard. Look at size and write activity.
depasseg
FreeNAS Replicant
Can you provide the output of zfs list and zpool status -v? Please either paste screenshots or text inside "code" tags.
mrramsey
[root@freenas ~]# zfs list
NAME														USED  AVAIL  REFER  MOUNTPOINT
freenas-boot												634M  6.65G	31K  none
freenas-boot/ROOT										   627M  6.65G	25K  none
freenas-boot/ROOT/Initial-Install							 1K  6.65G   622M  legacy
freenas-boot/ROOT/Wizard-2016-11-17_15:01:12				  1K  6.65G   622M  legacy
freenas-boot/ROOT/default								   627M  6.65G   624M  legacy
freenas-boot/grub										  6.33M  6.65G  6.33M  legacy
storage-													114G  1.64T  24.7G  /mnt/storage-
storage-/.system										   10.6M  1.64T  8.61M  legacy
storage-/.system/configs-810048d7feed436fae88f4409435135f   172K  1.64T   172K  legacy
storage-/.system/cores									  808K  1.64T   808K  legacy
storage-/.system/rrd-810048d7feed436fae88f4409435135f		96K  1.64T	96K  legacy
storage-/.system/samba4									 368K  1.64T   368K  legacy
storage-/.system/syslog-810048d7feed436fae88f4409435135f	568K  1.64T   568K  legacy
storage-/jails											   96K  1.64T	96K  /mnt/storage-/jails
storage-/shared											89.6G  1.64T  89.6G  /mnt/storage-/shared
[root@freenas ~]#
[root@freenas ~]# zpool ststus -v
unrecognized command 'ststus'
usage: zpool command args ...
where 'command' is one of the following:
		create [-fnd] [-o property=value] ...
			[-O file-system-property=value] ...
			[-m mountpoint] [-R root] <pool> <vdev> ...
		destroy [-f] <pool>
		add [-fn] <pool> <vdev> ...
		remove <pool> <device> ...
		labelclear [-f] <vdev>
		list [-Hpv] [-o property[,...]] [-T d|u] [pool] ... [interval [count]]
		iostat [-v] [-T d|u] [pool] ... [interval [count]]
		status [-vx] [-T d|u] [pool] ... [interval [count]]
		online [-e] <pool> <device> ...
		offline [-t] <pool> <device> ...
		clear [-nF] <pool> [device]
		reopen <pool>
		attach [-f] <pool> <device> <new-device>
		detach <pool> <device>
		replace [-f] <pool> <device> [new-device]
		split [-n] [-R altroot] [-o mntopts]
			[-o property=value] <pool> <newpool> [<device> ...]
		scrub [-s] <pool> ...
		import [-d dir] [-D]
		import [-d dir | -c cachefile] [-F [-n]] <pool | id>
		import [-o mntopts] [-o property=value] ...
			[-d dir | -c cachefile] [-D] [-f] [-m] [-N] [-R root] [-F [-n]] -a
			<pool | id> [newpool]
		export [-f] <pool> ...
		upgrade [-v]
		upgrade [-V version] <-a | pool ...>
		reguid <pool>
		history [-il] [<pool>] ...
		get [-Hp] [-o "all" | field[,...]] <"all" | property[,...]> <pool> ...
		set <property=value> <pool>
[root@freenas ~]#
depasseg
FreeNAS Replicant
You had a typo in your command. It's zpool status -v
mrramsey
Sorry about that... fat finger friday i guess.
[root@freenas ~]# zpool status -v
  pool: freenas-boot
state: ONLINE
  scan: none requested
		NAME										  STATE	 READ WRITE CKSUM
		freenas-boot								  ONLINE	   0	 0	 0
		  gptid/759ac1c3-acc4-11e6-9597-001018cc0b04  ONLINE	   0	 0	 0
errors: No known data errors
  pool: storage-
state: ONLINE
		storage-										ONLINE	   0	 0	 0
		  mirror-0									  ONLINE	   0	 0	 0
			gptid/89c824d7-ad00-11e6-a1bc-001018cc0b04  ONLINE	   0	 0	 0
			gptid/8a642467-ad00-11e6-a1bc-001018cc0b04  ONLINE	   0	 0	 0
[root@freenas ~]#
You have a healthy mirror. That means, necessarily, that both disks are in sync. If the system detects that it's otherwise, it will let you know (assuming you've set up email notifications as you should).
abhishek
I have custom nas with AMD FX(tm) 8 Core processor with 2x8 GB RAM and Zotac 2GB Graphics Card
I created pool mirror-0 how to check mirror drive and how to verify that data get stored in mirrored drive?
You do exactly what I said above: look at the pool status. If it says the pool is healthy, the data is stored on the mirrored drive.
