I intend to use FreeNAS with different harddisks, which are NTFS-formatted and partitioned in different drives. One disk should be in permanent use, the others should be inserted when needed (hot swapping).
Are there limitations, if NTFS is used?
Is it possible to operate it that way or do all disks have to be inserted all the time?
