EvanVanVan
- Feb 1, 2014
Edit2: Solved. For those wondering:
Is it normal for the USB on which FreeNAS is installed to show that it's formatted using a legacy on-disk format?
The guide section regarding upgrading a ZFS pool, only mentions the actual data pool. I'm not entirely sure how the USB stick itself is formatted, or what the result of running a "zpool upgrade" on it would be.
Any suggestions?
Thanks
edit:
Don't upgrade it.
See this thread - https://forums.freenas.org/index.php?threads/psa-do-not-upgrade-your-boot-pools.42355/#post-274580
Any suggestions?
Thanks
edit:
zpool status pool: freenas-boot state: ONLINE status: The pool is formatted using a legacy on-disk format. The pool can still be used, but some features are unavailable. action: Upgrade the pool using 'zpool upgrade'. Once this is done, the pool will no longer be accessible on software that does not support feature flags. scan: scrub repaired 0 in 0h1m with 0 errors on Sun Feb 28 03:46:56 2016 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da8p2 ONLINE 0 0 0 errors: No known data errors
