root@freenas:/mnt/ZFSPOOL/home/admin# docker inspect 126768e7ab56
"Id": "126768e7ab5663c577ca2d288b881b22066c239432dfe34b1749a1f2f85e3073",
"Created": "2021-07-01T03:37:17.390893773Z",
"Path": "docker-entrypoint.sh",
"Args": [
"node",
"server/bin/www"
"State": {
"Status": "running",
"Running": true,
"Paused": false,
"Restarting": false,
"OOMKilled": false,
"Dead": false,
"Pid": 24789,
"ExitCode": 0,
"Error": "",
"StartedAt": "2021-07-01T03:37:25.902131791Z",
"FinishedAt": "0001-01-01T00:00:00Z"
"Image": "sha256:68fde10819c7649c0909b98856a3473ea0a8775292135cbf4f23dce57681be86",
"ResolvConfPath": "/mnt/ZFSPOOL/ix-applications/docker/containers/5752d0146eb6f5b5e8de01801e8eaa941af845c8eb248079b7dbe810da41bbd9/resolv.conf",
"HostnamePath": "/mnt/ZFSPOOL/ix-applications/docker/containers/5752d0146eb6f5b5e8de01801e8eaa941af845c8eb248079b7dbe810da41bbd9/hostname",
"HostsPath": "/var/lib/kubelet/pods/3bb6526b-41e6-4999-b6f0-81eb35c4e1d7/etc-hosts",
"LogPath": "/mnt/ZFSPOOL/ix-applications/docker/containers/126768e7ab5663c577ca2d288b881b22066c239432dfe34b1749a1f2f85e3073/126768e7ab5663c577ca2d288b881b22066c239432dfe34b1749a1f2f85e3073-json.log",
"Name": "/k8s_ix-chart_zwavejs2mqtt-ix-chart-5b5b7f857b-vgq26_ix-zwavejs2mqtt_3bb6526b-41e6-4999-b6f0-81eb35c4e1d7_6",
"RestartCount": 0,
"Driver": "zfs",
"Platform": "linux",
"MountLabel": "",
"ProcessLabel": "",
"AppArmorProfile": "unconfined",
"ExecIDs": null,
"HostConfig": {
"Binds": [
"/mnt/ZFSPOOL/docker-data/zwavejs2mqtt:/usr/src/app/store",
"/mnt/ZFSPOOL/docker-data/docker_shared:/shared",
"/mnt/ZFSPOOL/docker-data/docker_storage:/storage",
"/var/lib/kubelet/pods/3bb6526b-41e6-4999-b6f0-81eb35c4e1d7/volumes/kubernetes.io~projected/kube-api-access-bznfj:/var/run/secrets/kubernetes.io/serviceaccount:ro",
"/var/lib/kubelet/pods/3bb6526b-41e6-4999-b6f0-81eb35c4e1d7/etc-hosts:/etc/hosts",
"/var/lib/kubelet/pods/3bb6526b-41e6-4999-b6f0-81eb35c4e1d7/containers/ix-chart/7d62f64f:/dev/termination-log"
"ContainerIDFile": "",
"LogConfig": {
"Type": "json-file",
"Config": {}
"NetworkMode": "container:5752d0146eb6f5b5e8de01801e8eaa941af845c8eb248079b7dbe810da41bbd9",
"PortBindings": null,
"RestartPolicy": {
"Name": "no",
"MaximumRetryCount": 0
"AutoRemove": false,
"VolumeDriver": "",
"VolumesFrom": null,
"CapAdd": null,
"CapDrop": null,
"CgroupnsMode": "host",
"Dns": null,
"DnsOptions": null,
"DnsSearch": null,
"ExtraHosts": null,
"GroupAdd": null,
"IpcMode": "container:5752d0146eb6f5b5e8de01801e8eaa941af845c8eb248079b7dbe810da41bbd9",
"Cgroup": "",
"Links": null,
"OomScoreAdj": 1000,
"PidMode": "",
"Privileged": true,
"PublishAllPorts": false,
"ReadonlyRootfs": false,
"SecurityOpt": [
"seccomp=unconfined",
"label=disable"
"UTSMode": "host",
"UsernsMode": "",
"ShmSize": 67108864,
"Runtime": "nvidia",
"ConsoleSize": [
0,
0
"Isolation": "",
"CpuShares": 2,
"Memory": 0,
"NanoCpus": 0,
"CgroupParent": "/kubepods/besteffort/pod3bb6526b-41e6-4999-b6f0-81eb35c4e1d7",
"BlkioWeight": 0,
"BlkioWeightDevice": null,
"BlkioDeviceReadBps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteIOps": null,
"CpuPeriod": 100000,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpusetCpus": "",
"CpusetMems": "",
"Devices": [],
"DeviceCgroupRules": null,
"DeviceRequests": null,
"KernelMemory": 0,
"KernelMemoryTCP": 0,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": null,
"OomKillDisable": false,
"PidsLimit": null,
"Ulimits": null,
"CpuCount": 0,
"CpuPercent": 0,
"IOMaximumIOps": 0,
"IOMaximumBandwidth": 0,
"MaskedPaths": null,
"ReadonlyPaths": null
"GraphDriver": {
"Data": {
"Dataset": "ZFSPOOL/ix-applications/docker/b17d658d11a0d4f620516ea93872a49e49a98e6dce0a81abab223b5ca9e8489b",
"Mountpoint": "/mnt/ZFSPOOL/ix-applications/docker/zfs/graph/b17d658d11a0d4f620516ea93872a49e49a98e6dce0a81abab223b5ca9e8489b"
"Name": "zfs"
"Mounts": [
"Type": "bind",
"Source": "/mnt/ZFSPOOL/docker-data/zwavejs2mqtt",
"Destination": "/usr/src/app/store",
"Mode": "",
"RW": true,
"Propagation": "rprivate"
"Type": "bind",
"Source": "/mnt/ZFSPOOL/docker-data/docker_shared",
"Destination": "/shared",
"Mode": "",
"RW": true,
"Type": "bind",
"Source": "/mnt/ZFSPOOL/docker-data/docker_storage",
"Destination": "/storage",
"Mode": "",
"RW": true,
"Type": "bind",
"Source": "/var/lib/kubelet/pods/3bb6526b-41e6-4999-b6f0-81eb35c4e1d7/volumes/kubernetes.io~projected/kube-api-access-bznfj",
"Destination": "/var/run/secrets/kubernetes.io/serviceaccount",
"Mode": "ro",
"RW": false,
"Type": "bind",
"Source": "/var/lib/kubelet/pods/3bb6526b-41e6-4999-b6f0-81eb35c4e1d7/etc-hosts",
"Destination": "/etc/hosts",
"Mode": "",
"RW": true,
"Type": "bind",
"Source": "/var/lib/kubelet/pods/3bb6526b-41e6-4999-b6f0-81eb35c4e1d7/containers/ix-chart/7d62f64f",
"Destination": "/dev/termination-log",
"Mode": "",
"RW": true,
"Config": {
"Hostname": "freenas",
"Domainname": "",
"User": "0",
"AttachStdin": false,
"AttachStdout": false,
"AttachStderr": false,
"ExposedPorts": {
"8091/tcp": {}
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"TZ=America/Edmonton",
"KUBERNETES_SERVICE_PORT=443",
"KUBERNETES_SERVICE_PORT_HTTPS=443",
"KUBERNETES_PORT=tcp://172.17.0.1:443",
"KUBERNETES_PORT_443_TCP=tcp://172.17.0.1:443",
"KUBERNETES_PORT_443_TCP_PROTO=tcp",
"KUBERNETES_PORT_443_TCP_PORT=443",
"KUBERNETES_PORT_443_TCP_ADDR=172.17.0.1",
"KUBERNETES_SERVICE_HOST=172.17.0.1",
"PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"NODE_VERSION=16.3.0",
"YARN_VERSION=1.22.5",
"ZWAVEJS_EXTERNAL_CONFIG=/usr/src/app/store/.config-db"
"Cmd": [
"node",
"server/bin/www"
"Healthcheck": {
"Test": [
"NONE"
"Image": "zwavejs/zwavejs2mqtt@sha256:d20129ad1b62e0bbdeec6a3e3a9bc1dd1d1cc9c755699036d2287689535ea2ee",
"Volumes": null,
"WorkingDir": "/usr/src/app",
"Entrypoint": [
"OnBuild": null,
"Labels": {
"annotation.io.kubernetes.container.hash": "1dedbd02",
"annotation.io.kubernetes.container.restartCount": "6",
"annotation.io.kubernetes.container.terminationMessagePath": "/dev/termination-log",
"annotation.io.kubernetes.container.terminationMessagePolicy": "File",
"annotation.io.kubernetes.pod.terminationGracePeriod": "30",
"io.kubernetes.container.logpath": "/var/log/pods/ix-zwavejs2mqtt_zwavejs2mqtt-ix-chart-5b5b7f857b-vgq26_3bb6526b-41e6-4999-b6f0-81eb35c4e1d7/ix-chart/6.log",
"io.kubernetes.container.name": "ix-chart",
"io.kubernetes.docker.type": "container",
"io.kubernetes.pod.name": "zwavejs2mqtt-ix-chart-5b5b7f857b-vgq26",
"io.kubernetes.pod.namespace": "ix-zwavejs2mqtt",
"io.kubernetes.pod.uid": "3bb6526b-41e6-4999-b6f0-81eb35c4e1d7",
"io.kubernetes.sandbox.id": "5752d0146eb6f5b5e8de01801e8eaa941af845c8eb248079b7dbe810da41bbd9",
"maintainer": "robertsLando",
"org.opencontainers.image.authors": "Daniel Lando <daniel.sorridi@gmail.com>",
"org.opencontainers.image.created": "2021-06-30T13:37:26.440Z",
"org.opencontainers.image.description": "Zwave to Mqtt gateway and Control Panel Web UI. Built using Nodejs, and Vue/Vuetify",
"org.opencontainers.image.documentation": "https://zwave-js.github.io/zwavejs2mqtt/#/",
"org.opencontainers.image.licenses": "MIT",
"org.opencontainers.image.revision": "f1671e41c13fedfb7d8b710b15b109e40fb5da31",
"org.opencontainers.image.source": "https://github.com/zwave-js/zwavejs2mqtt",
"org.opencontainers.image.title": "zwavejs2mqtt",
"org.opencontainers.image.url": "https://zwave-js.github.io/zwavejs2mqtt/#/",
"org.opencontainers.image.vendor": "zwave-js",
"org.opencontainers.image.version": "5.2.1"
"NetworkSettings": {
"Bridge": "",
"SandboxID": "",
"HairpinMode": false,
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"Ports": {},
"SandboxKey": "",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null,
"EndpointID": "",
"Gateway": "",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": "",
"Networks": {}
