First build in 3u rack case
TinyWorkshop
Hi all
I’m going to try my first build after years on Synology NAS :grin:
for my build I think to go for a 5/6 sata drive , and a couple Of nvme (separate volume)
minimum 32 gb of ram
I plan to use docker and probably a Vm
I plan also to install Plex and do some transcoding (max 2 simultaneously)
connection via 10Gbe
any advice on some good mini itx-micro atx motherboard / cpu combo?
all will have to fit a short 3u rack case
thanks for any advice I’m a bit lost at the moment :smile:
Davvo
I am totally green about NAS, so I can't help you, but I do have a question.
What will you use your nvme drives for?
TinyWorkshop
Just as a fast network disk for temporary work.
I will back up it daily.
I’m not a big fan of cashing… but I have to experiment a bit, maybe with Zfs it’s better? :)
