ESXi 7.0 not discovering iSCSI LUNs
Marco3G
Hi everyone
I'm trying to configure iSCSI to use as datastores for ESXi hosts.
I created a vdev in a new pool containing three NVMe drives. I then created two Zvols and added them as extents to the iSCSI config. I set Logical Block Size to 512 and left block size reporting enabled. I also left TPC enabled.
I have one 10G NIC in the TrueNAS box as well as the ESXi hosts. I have configured the hosts to use IPs 192.168.5.2 and 3 and TrueNAS has a VLAN configured with IP 192.168.5.110.
I have added a vmk adapter on the hosts and I entered the IP 192.168.5.110 for dynamic discovery.
I have tested pings from TrueNAS to the hosts and I did vmkping -I vmk1 192.168.5.110 from the hosts. Works fine!
TrueNAS lists no connected initiators.
I have not configured any authentication. I have searched on here but I seem to be finding primarily posts from FreeNAS times.
Can someone help me finding out what is going wrong here?
Marco3G
Never mind... under the Initiators tab I had an old subnet configured for allowed networks... obviously it then did not respond on the correct subnet. My bad.
