I installed FreeNAS 9.3 a while ago on a USB drive on my HP Microserver with 16GB. Recently, I installed 4 WD Green 4TB drives. After a short learning curve, everything seemed OK. I transferred a few TB of data on to it. Then, the green indicator at the upper right of the screen started blinking red. I don't remember the exact wording, but basically said something about drive ADA1 disconnected or failed. Also, it said (And still says):
CRITICAL: The volume MyPool (ZFS) state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
When I reboot, the drive comes back. This happened 3 or 4 times on the same drive, then it happened on ADA3 once. Currently, it has run overnight without any new error. I unchecked the above message, and the green light is back. I'm unsure how to get rid of the message.
The drives SMART are all OK. Before I plugged in the USB drive with FreeNAS, I ran Memtest over a long weekend, and then manually re-ran HD Tune repeatedly on each drive over another long weekend. I never saw the slightest hint of hardware problems. I also configured the drives to park every 300 seconds instead of every 8 seconds.
As I'm new to FreeNAS, I don't know where the log files are (I looked). Under 'View Volumes', it shows the status as Healthy.
I believe the RAID is a Z2.
Any ideas? Since these drives are not tuned for NAS use, maybe they are timing out? Any other ideas or solutions?
Thanks!
Thanks!
