Docker: Command not found. Docker removed in 23.10?
blademan
That was on the roadmap from the beginning... the model for SCALE is Kubernetes, not docker.
Originally the docker engine was used, but the decision to move to containerd was made very early in SCALE's development and finally docker was removed in Bluefin.
You have 2 options to use docker compose...
1. Use the TrueCharts Docker-compose app (only allows for one compose app).
2. Use ubernerd or jailmaker (will be docker on containerd). https://www.truenas.com/community/threads/linux-jails-experimental-script.106926/ https://www.truenas.com/community/posts/735320/
