SOLVED docker bind mount propagation
crispyduck
is there any way to set the bind mount propagation? Inspecting the containers, it defaults to rprivate; I would need shared, but can't find a way to set it via gui/cli.
Br crispyduck
crispyduck
Found it myself. Simply add :rslave to the dest mount path. e.g.: /mnt:rslave will result to:
"Type": "bind",
"Source": "/mnt/pool1/dataset1_1",
"Destination": "/mnt",
"Mode": "rslave",
"RW": true,
"Propagation": "rslave"
This is exactly what I needed, so the mount point is automatically created/deleted when adding/deleting child datasets.
