gyorfitam
- Jan 20, 2021
I have a DIY NAS that runs TrueNAS-13.0-U6.1. I put this system together a while ago and noticed that if I run the machine for a while (few days for example), the web GUI becomes unavailable and I also can't see the device being connected to the router. After reading a bit about this, the recommendation seems to be to use different NIC rather than the (supposedly crappy) Realtek one on the motherboard. Generally the recommendation was to get an Intel one if I'm only going to use a gigabit connection, so I did buy a new Intel EXPI9301CTBLK Gigabit PRO 1000CT card, this was one of the recommended ones in one of the articles I've found. And the issue still persist - although doesn't seem to be as severe as earlier (I only checked it after around 2 weeks of running as after few days it was still fine). I don't even know how to test this issue properly so I'm not sure when did the network shutdown for example. I tried to reboot it by connecting a keyboard to it but it didn't react to it for some reason so in this scenario the only option I have AFAIK is to press the reset button on the case. The recommendation is to run the NAS constantly as it is better for the hard drives and all the automated checks (SMART, Scrub) can go through regularly, I get it. But if it keeps disconnecting, I don't think it's that great for this system that I have to force restart quite regularly. What if I restart it while scrubbing is happening? Is there any way to check if any scheduled task is happening right now while the web GUI is not available? The command line is not really showing anything - especially if you can't interact with it (not reacting to keyboard).
Any ideas what can cause this issue and how to solve it?
Some info about the system:
- ASRock B450 Steel Legend motherboard
- AMD Ryzen 5 1400 CPU
- 16GB (2x 8GB) unbuffered ECC RAM
- Boot drive is a 128GB M.2 NVME drive (TS128GMTE110S)
- There's 14 hard drives in the system in total. There is 3 vdevs, each consists of 4 drives (RAIDz1), 2 hard drives are spares. 8 hard drives are connected to an HBA, 4 to motherboard, the 2 spares to a simple dual PCIE X1 SATA card. They are a combination of WD Purple and Red drives (non of them are SMR drives).
