Disk Health showing errors due to aborted smart test
m9x3mos
Hi all,
I have this message when I look at the storage section:
When looking at the failed smart tests it is because they were aborted or canceled due to reboots and there are no errors with the disks after running and extended test on them overnight.
Is there a way to clear that error or previous smart tests to get rid of the false warning?
There's an open ticket on this; see:
Mannekino
Hi, I had the exact same question. I have a warning also due to 10 failed S.M.A.R.T. tests in the past which have been aborted. Hopefully this behavior will change.
kalidus
Happened to me aswell on 2 12tb disks...almost had a heart attack.
Mannekino
This should be resolved in the current SCALE release.
Thanks for the info.
I had not updated yet, but just did. Can confirm, I now get a green checkmark under "Disk Health". Great to see, thanks!
