Since this is not available, how would this be done from the CLI or SSH
Try the following, but be aware that destroying the volume on SSH will not remove it from FreeNAS GUI (you will need to edit the /data/freenas-v1.db with HeidiSQL (there are other threads explaining how to do this) :-
[root@freenas] /mnt# zpool list
NAME SIZE USED AVAIL CAP HEALTH ALTROOT
hdd1 5.45T 1.51T 3.94T 27% ONLINE /mnt
[root@freenas] /mnt#zpool destroy hdd1
Here's a list of other useful commands, "dd" commands to be used with caution!!
mounting an external ntfs drive
mount -ft ntfs /dev/da1p1 /mnt/usb/
umount /mnt/usb
exporting a disk after GUI fails
zpool export hdd0
copy files recursively without overwriting (verbose)
cp -nrv * /dest
view the process status
ps ax
display folder size and disk sizes
du -sf /dir
df
data duplication and formatting tasks
dd if=/mnt/hdd1 of=/mnt/usb0 bs=1m
dd if=/dev/zero of=/dev/ada1 bs=512 count=2
dd if=/dev/zero of=/dev/ada1 bs=512 skip=sectors
backup hdd1 to usb drive
rsync -av --delete /mnt/hdd1/ /mnt/usb/
fsck - check and repair a Linux file system
md5sum
determining sector size on hard disk
zpool set cachefile=/data/zfs/zpool.cache hdd1
zdb -U /data/zfs/zpool.cache | grep ashift
If the answer = 9, you have 512 byte sectors.
If the answer = 12, you have 4k byte sectors.
list all files recursively as .csv to output file
ll -Raml >files.txt
useful volume management commands
gmirror status
gpart show
zpool list
zpool status
camcontrol devlist
zfs list
destroy the GPT at beginning and end of drive
sysctl kern.geom.debugflags=0x10
dd if=/dev/zero of=/dev/da0 bs=1m count=1
dd if=/dev/zero of=/dev/da0 bs=1m oseek=`diskinfo ada0 | awk '{print int($3 / (1024*1024)) - 4;}'`
rename a volume
export from GUI
zpool import usb usb2
zpool status -v
zpool import -R /mnt 1462612345814408114 usb
