Deanmrd
- Feb 22, 2020
Hello Everyone
I have x2 3TB drives one striped so the data is backed up the current drives are not nas drives I know nas drive last long with this usage. I have now ordered x 2 4TB wd red drivers I wont to replace them with the 3TB drives. I would like advice on how to tell what drive is faulty. and how to swop the drives over
I have just noticed an issue with my FreeNAS server says that it is degraded I think this might be one of the hard drives I have taken a number of screenshots
thanks in advance
dean
nvalid option 'P' usage: list [-Hpv] [-o property[,...]] [-T d|u] [pool] ... [interval [count]] the following properties are supported: PROPERTY EDIT VALUES allocated NO <size> capacity NO <size> checkpoint NO <size> dedupratio NO <1.00x or higher if deduped> expandsize NO <size> fragmentation NO <percent> free NO <size> freeing NO <size> guid NO <guid> health NO <state> leaked NO <size> size NO <size> altroot YES <path> autoexpand YES on | off autoreplace YES on | off bootfs YES <filesystem> bootsize YES <size> cachefile YES <file> | none comment YES <comment-string> dedupditto YES <threshold (min 100)> delegation YES on | off
thanks in advance
dean
