Hey Guys.
I run FreeNAS 11.0 on a DL360_G6 with a SAS Controller and some SATA Disks in a VLS9000 Chassis.
I have mix 1TB and 2TB Disks. On the GUI i cant create a pool with all Disks, i cant Mix booth sizes. I know that i can use only the size of the smallest Disk. I also want use the da1p1.eli instead of da1. I want use geli for Encrypting each da1p1. Its possible to run this way?
thanks ré
thanks ré
