SOLVED Connecting to a different network for Backup
Alpha-Inc.
Hello everybody,
I run a FreeNAS Server and just moved into a new apartment. So far I set up my network (192.168.10.0/24) and have all devices running (Clients, FreeNAS and three Debian VMs). Now I wanted to set a connection to my parents home-network (different subnet; 192.168.11.0/24) since there will be another server my FreeNAS machine will create ZFS-Replaction backups to. The question I now have is, how do I set a safe connection to the other network (over the internet) to transfer the backup?
I did a bit of research and read many articles about a VPN (which I have thought about too). Our routers have the possibility to set up an IPSec VPN by default (without the need of an extra device or VM). I have a few ideas how to go on from now and I thought maybe someone could help me in finding the best and safest way:
1) Connect my FreeNAS Server to my parent's network with an IPSec client to be part of their network and transfer the files to the Backup-Server
2) Use tinc to connect both networks with each other
3) Other ideas I haven't thought of?
Would be great if someone could help me with this. Thank you in advance.
TrueNAS 12.0 CORE and higher (which is the upgrade from FreeNAS 11 and is still free) has the OpenVPN service for both client and server built-in.
I would suggest using that as a server on one end and a client on the other, which then removes any complication with handling networks other than the 2 TrueNAS systems which would communicate with each other on the configured VPN network addresses only.
Alpha-Inc.
Ah okay sounds good. Thanks.
