clear L2Arc ?
HoneyBadger
actually does care
Administrator
Easiest ways are:
  1. Reboot, if you haven't set it to be persistent.
  2. Remove the L2ARC device(s) from the pool and re-add them.
Counter-question: Why? If it's for benchmarking, setting secondarycache=none on the dataset/zvol in question is faster.
Janko
Thanks for Reply.
Both Options not possible at the Moment.
Its an active VM Storage.
We had some performance Issues and i saw the NAS-106992 Entry.
HoneyBadger
actually does care
Administrator
Have you set the tunable for pL2ARC (vfs.zfs.l2arc.rebuild_enabled)? Bug seems to refer to delay/middleware UI timeouts when reindexing a large L2ARC.
Are you using iSCSI? Can you elaborate further on the performance issues?
