CIFS Export Recycle Bin capacity limit
marian78
Hi, i read freenas docs and i cant find any information about default CIFS recycle bin maximum capacity.....
Can you pleas post info?
SweetAndLow
Sweet'NASty
What do you mean by maximum capacity? Recycle bin option just moved deleted files into your .recycle bin.
marian78
How much file (in MiB) i can delete (move to .recycle) from CIFS share without loosing.
Example: i have dataset with 10TiB of files/folders (many many files/folders). If inadvertently select all files/folders and delete them, will i find all in .recycle?
Yep. There is no limit to its size. Likewise things aren't deleted from .recycle automatically for any reason. You have to manually delete them.
marian78
ok, thats good for me. I like that there is no limit. Thx, sir.
