Can't remove offline pool (TN Scale)
stavros-k
I had created a pool on SCALE with only 1 disk just to test some things, until my new disks arrive. I have unplugged the disk (the 1st pool) and connected the 4 new disks.
Created a new pool which is working fine.
Now i want remove the 1st pool, on Storage tab i can see the pool "OFFLINE" but no gear icon or anything to delete it.
On zpool status it's not listed. I can only see the boot-pool and the new 4disk pool.
Is this a bug? should it be reported on jira?
Thanks
blaco
Have you found a solution for this issue?
I also have a pool which is offline on the UI after I did an extense migration for new disks (and forgot to export the pool before disconnecting the disks). The disks are not connected to the server anymore and I have no possibility to insert them back. I still couldn't find a soluhtion to delete this pool (entry) on the UI/Config. If I select "Export/Disconnect", I get the error [ENOENT] None: PoolDataset S8TB does not exist.
Zfs commands from the commandline don't show this pool anymore.
Version: TrueNAS-SCALE-22.02-RC.2
stavros-k
I don't exactly remember, but I think it was a bug with a nightly that has been fixed, I reverted or upgraded to the next and fixed the issue.
But I would suggest filing a Jira ticket. So it can be fixed and won't cause this problem to other people
I dealt with this "zombie pool" issue in CORE a long time ago... probably the same thing.
  • Like
Reactions: vpv
