AwesomeNick566
- Nov 6, 2015
Hi there. While trying to get FreeNAS set up, I ran into a problem. At first, FreeNAS intalled onto the device that I wished to boot it from, but after booting it for the first time, It ran through some commands for about 1-2 minutes, and it then said "can't exec /bin/sh for /etc/rc: Input/output error". It also asked me to type the full pathname for /bin/sh. If you need my device specs, I have posted them in this thread.
EDIT:
If you'd like to see the logs before the error occured, I have posted them here: http://i.imgur.com/M5BZaNj.jpg
Sorry if some parts look a bit distorted, I took it as a panorama shot on my phone.
I really would like to have FreeNAS up and running soon, so please respond as soon as you can.
Specs:
Computer:
Type: Desktop
Architecture: 64-bit (x64)
Manufacturer: HP
Disk Size: 500GB (this disk will be used for storage, not installation)
RAM: 8GB
Connected with Ethernet to router: Yes
Processor: Intel i5
Device which FreeNAS is installed on:
Type: USB Stick
Manufacturer: SanDisk
Disk Size: 16GB (this disk used for installation)
EDIT:
Specs:
Computer:
Type: Desktop
Manufacturer: HP
RAM: 8GB
Processor: Intel i5
Type: USB Stick
