C2750D4I + eSATA Expansion Card Issue
MattG
After searching the forums for FreeNAS compatible eSATA expansion cards I purchased the Startech pexesata2, that is based on the SiI3132 chipset (http://www.startech.com/Cards-Adapters/HDD-Controllers/SATA-Cards/2-Port-PCI-Express-eSATA-Controller-Card~PEXESATA2). I am having issues getting the hardware to detect the card, and wanted to see if anybody can spot anything obvious before I return it. I went through the BIOS top to bottom to make sure it wasn't an issue there. Here are the specs and the output from various commands, let me know if you need anything else.
FreeNAS build: FreeNAS-9.3-STABLE-201503270027
uname -a:
FreeBSD freenas.local 9.3-RELEASE-p12 FreeBSD 9.3-RELEASE-p12 #2 r275790+e006356: Thu Mar 26 17:28:49 PDT 2015     root@build3.ixsystems.com:/tank/home/jkh/build/FN/objs/os-base/amd64/tank/home/jkh/build/FN/FreeBSD/src/sys/FREENAS.amd64  amd64
Hardware:
ASRock C2750D4I Mini ITX Server Motherboard
Crucial 16GB Kit (8GBx2) DDR3/DDR3L-1600MT/s (PC3-12800) DR x8 ECC UDIMM Server Memory CT2KIT102472BD160B/CT2CP102472BD160B
ADATA S102 16GB USB 3.0 Flash Drive Model AS102P-16G-RGY
SILVERSTONE ST45SF-G 450W SFX12V SLI Ready CrossFire Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
5x WDC WD20EFRX-68EUZN0 (2TB)
3x SAMSUNG HD204UI (2TB)
Startech 2 Port PCI Express eSATA Controller Adapter Card Model pexesata2
1x  WD Red WD40EFRX (4TB) (In an external enclosure, attached to the eSATA card)
Rosewill RX-358 V2 BLK - Black, 3.5" SATA to USB & eSATA External Enclosure with Internal 80 mm Fan
camcontrol devlist:
<WDC WD20EFRX-68EUZN0 82.00A82>    at scbus0 target 0 lun 0 (pass0,ada0)
<WDC WD20EFRX-68EUZN0 80.00A80>    at scbus1 target 0 lun 0 (pass1,ada1)
<WDC WD20EFRX-68EUZN0 80.00A80>    at scbus2 target 0 lun 0 (pass2,ada2)
<WDC WD20EFRX-68EUZN0 82.00A82>    at scbus3 target 0 lun 0 (pass3,ada3)
<SAMSUNG HD204UI 1AQ10001>         at scbus4 target 0 lun 0 (pass4,ada4)
<SAMSUNG HD204UI 1AQ10001>         at scbus5 target 0 lun 0 (pass5,ada5)
<Marvell Console 1.01>             at scbus9 target 0 lun 0 (pass6)
<WDC WD20EFRX-68EUZN0 82.00A82>    at scbus14 target 0 lun 0 (pass7,ada6)
<SAMSUNG HD204UI 1AQ10001>         at scbus15 target 0 lun 0 (pass8,ada7)
<ADATA USB Flash Drive 1100>       at scbus17 target 0 lun 0 (pass9,da0)
pciconf -lv:
hostb0@pci0:0:0:0:    class=0x060000 card=0x00000000 chip=0x1f018086 rev=0x02 hdr=0x00
    vendor     = 'Intel Corporation'
    class      = bridge
    subclass   = HOST-PCI
pcib1@pci0:0:1:0:    class=0x060400 card=0x1f101849 chip=0x1f108086 rev=0x02 hdr=0x01
    class      = bridge
    subclass   = PCI-PCI
pcib2@pci0:0:3:0:    class=0x060400 card=0x1f121849 chip=0x1f128086 rev=0x02 hdr=0x01
    class      = bridge
    subclass   = PCI-PCI
pcib9@pci0:0:4:0:    class=0x060400 card=0x1f131849 chip=0x1f138086 rev=0x02 hdr=0x01
    class      = bridge
    subclass   = PCI-PCI
hostb1@pci0:0:14:0:    class=0x060000 card=0x1f141849 chip=0x1f148086 rev=0x02 hdr=0x00
    class      = bridge
    subclass   = HOST-PCI
none0@pci0:0:15:0:    class=0x080600 card=0x1f161849 chip=0x1f168086 rev=0x02 hdr=0x00
    class      = base peripheral
none1@pci0:0:19:0:    class=0x088000 card=0x1f151849 chip=0x1f158086 rev=0x02 hdr=0x00
ehci0@pci0:0:22:0:    class=0x0c0320 card=0x1f2c1849 chip=0x1f2c8086 rev=0x02 hdr=0x00
    class      = serial bus
    subclass   = USB
ahci2@pci0:0:23:0:    class=0x010601 card=0x1f221849 chip=0x1f228086 rev=0x02 hdr=0x00
    class      = mass storage
    subclass   = SATA
ahci3@pci0:0:24:0:    class=0x010601 card=0x1f321849 chip=0x1f328086 rev=0x02 hdr=0x00
    subclass   = SATA
isab0@pci0:0:31:0:    class=0x060100 card=0x1f381849 chip=0x1f388086 rev=0x02 hdr=0x00
    class      = bridge
    subclass   = PCI-ISA
none2@pci0:0:31:3:    class=0x0c0500 card=0x1f3c1849 chip=0x1f3c8086 rev=0x02 hdr=0x00
    class      = serial bus
    subclass   = SMBus
pcib3@pci0:2:0:0:    class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
    vendor     = 'PLX Technology, Inc.'
    device     = 'PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch'
    class      = bridge
    subclass   = PCI-PCI
pcib4@pci0:3:1:0:    class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
    class      = bridge
    subclass   = PCI-PCI
pcib5@pci0:3:5:0:    class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
    class      = bridge
    subclass   = PCI-PCI
pcib7@pci0:3:7:0:    class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
    class      = bridge
    subclass   = PCI-PCI
pcib8@pci0:3:9:0:    class=0x060400 card=0x860810b5 chip=0x860810b5 rev=0xba hdr=0x01
    class      = bridge
    subclass   = PCI-PCI
ahci0@pci0:4:0:0:    class=0x010601 card=0x91721849 chip=0x91721b4b rev=0x11 hdr=0x00
    vendor     = 'Marvell Technology Group Ltd.'
    subclass   = SATA
pcib6@pci0:5:0:0:    class=0x060400 card=0x11501849 chip=0x11501a03 rev=0x02 hdr=0x01
    vendor     = 'ASPEED Technology, Inc.'
    device     = 'AST1150 PCI-to-PCI Bridge'
    class      = bridge
    subclass   = PCI-PCI
vgapci0@pci0:6:0:0:    class=0x030000 card=0x20001849 chip=0x20001a03 rev=0x21 hdr=0x00
    device     = 'ASPEED Graphics Family'
    class      = display
    subclass   = VGA
igb0@pci0:7:0:0:    class=0x020000 card=0x15331849 chip=0x15338086 rev=0x03 hdr=0x00
    class      = network
    subclass   = ethernet
igb1@pci0:8:0:0:    class=0x020000 card=0x15331849 chip=0x15338086 rev=0x03 hdr=0x00
    class      = network
    subclass   = ethernet
ahci1@pci0:9:0:0:    class=0x010601 card=0x92301849 chip=0x92301b4b rev=0x11 hdr=0x00
    subclass   = SATA
dmesg:
Copyright (c) 1992-2014 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
    The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Atom(TM) CPU  C2750  @ 2.40GHz (2400.06-MHz K8-class CPU)
  Origin = "GenuineIntel"  Id = 0x406d8  Family = 0x6  Model = 0x4d  Stepping = 8
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x43d8e3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1,SSE4.2,MOVBE,POPCNT,TSCDLT,AESNI,RDRAND>
  AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
  AMD Features2=0x101<LAHF,Prefetch>
  Standard Extended Features=0x2282<TSCADJ,SMEP,ENHMOVSB>
  TSC: P-state invariant, performance statistics
real memory  = 17985175552 (17152 MB)
avail memory = 16489648128 (15725 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <INTEL  TIANO   >
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 1 package(s) x 8 core(s)
cpu0 (BSP): APIC ID:  0
cpu1 (AP): APIC ID:  2
cpu2 (AP): APIC ID:  4
cpu3 (AP): APIC ID:  6
cpu4 (AP): APIC ID:  8
cpu5 (AP): APIC ID: 10
cpu6 (AP): APIC ID: 12
cpu7 (AP): APIC ID: 14
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: FADT (revision 5) is longer than ACPI 5.0 version, truncating length 268 to 256 (20111123/tbfadt-325)
ioapic0 <Version 2.0> irqs 0-23 on motherboard
ispfw: registered firmware <isp_1040>
ispfw: registered firmware <isp_1040_it>
ispfw: registered firmware <isp_1080>
ispfw: registered firmware <isp_1080_it>
ispfw: registered firmware <isp_12160>
ispfw: registered firmware <isp_12160_it>
ispfw: registered firmware <isp_2100>
ispfw: registered firmware <isp_2200>
ispfw: registered firmware <isp_2300>
ispfw: registered firmware <isp_2322>
ispfw: registered firmware <isp_2400>
ispfw: registered firmware <isp_2400_multi>
ispfw: registered firmware <isp_2500>
ispfw: registered firmware <isp_2500_multi>
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
padlock0: No ACE support.
acpi0: <ALASKA A M I > on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
cpu4: <ACPI CPU> on acpi0
cpu5: <ACPI CPU> on acpi0
cpu6: <ACPI CPU> on acpi0
cpu7: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 450
Event timer "HPET1" frequency 14318180 Hz quality 440
Event timer "HPET2" frequency 14318180 Hz quality 440
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: Warning: Couldn't map I/O.
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> mem 0xdf740000-0xdf75ffff irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> mem 0xdf720000-0xdf73ffff irq 20 at device 3.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> mem 0xdf500000-0xdf51ffff irq 22 at device 0.0 on pci2
pci3: <ACPI PCI bus> on pcib3
pcib4: <PCI-PCI bridge> irq 23 at device 1.0 on pci3
pci4: <PCI bus> on pcib4
ahci0: <Marvell 88SE9172 AHCI SATA controller> port 0xc040-0xc047,0xc030-0xc033,0xc020-0xc027,0xc010-0xc013,0xc000-0xc00f mem 0xdf410000-0xdf4101ff irq 23 at device 0.0 on pci4
ahci0: AHCI v1.00 with 2 6Gbps ports, Port Multiplier supported with FBS
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
pcib5: <PCI-PCI bridge> irq 23 at device 5.0 on pci3
pci5: <PCI bus> on pcib5
pcib6: <PCI-PCI bridge> irq 23 at device 0.0 on pci5
pci6: <PCI bus> on pcib6
vgapci0: <VGA-compatible display> port 0xb000-0xb07f mem 0xde000000-0xdeffffff,0xdf000000-0xdf01ffff irq 23 at device 0.0 on pci6
vgapci0: Boot video device
pcib7: <PCI-PCI bridge> irq 21 at device 7.0 on pci3
pci7: <PCI bus> on pcib7
igb0: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xa000-0xa01f mem 0xdf300000-0xdf37ffff,0xdf380000-0xdf383fff irq 21 at device 0.0 on pci7
igb0: Using MSIX interrupts with 5 vectors
igb0: Ethernet address: d0:50:99:50:44:ab
igb0: Bound queue 0 to cpu 0
igb0: Bound queue 1 to cpu 1
igb0: Bound queue 2 to cpu 2
igb0: Bound queue 3 to cpu 3
pcib8: <PCI-PCI bridge> irq 23 at device 9.0 on pci3
pci8: <PCI bus> on pcib8
igb1: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0x9000-0x901f mem 0xdf200000-0xdf27ffff,0xdf280000-0xdf283fff irq 23 at device 0.0 on pci8
igb1: Using MSIX interrupts with 5 vectors
igb1: Ethernet address: d0:50:99:50:44:ac
igb1: Bound queue 0 to cpu 4
igb1: Bound queue 1 to cpu 5
igb1: Bound queue 2 to cpu 6
igb1: Bound queue 3 to cpu 7
pcib9: <ACPI PCI-PCI bridge> mem 0xdf700000-0xdf71ffff at device 4.0 on pci0
pci9: <ACPI PCI bus> on pcib9
ahci1: <Marvell 88SE9230 AHCI SATA controller> port 0xd050-0xd057,0xd040-0xd043,0xd030-0xd037,0xd020-0xd023,0xd000-0xd01f mem 0xdf610000-0xdf6107ff irq 23 at device 0.0 on pci9
ahci1: AHCI v1.20 with 8 6Gbps ports, Port Multiplier not supported
ahci1: quirks=0x900<NOBSYRES,ALTSIG>
ahcich2: <AHCI channel> at channel 0 on ahci1
ahcich3: <AHCI channel> at channel 1 on ahci1
ahcich4: <AHCI channel> at channel 2 on ahci1
ahcich5: <AHCI channel> at channel 3 on ahci1
ahcich6: <AHCI channel> at channel 4 on ahci1
ahcich7: <AHCI channel> at channel 5 on ahci1
ahcich8: <AHCI channel> at channel 6 on ahci1
ahcich9: <AHCI channel> at channel 7 on ahci1
ehci0: <Intel Avoton USB 2.0 controller> mem 0xdf763000-0xdf7633ff irq 23 at device 22.0 on pci0
usbus0: EHCI version 1.0
usbus0 on ehci0
ahci2: <Intel Avoton AHCI SATA controller> port 0xe0d0-0xe0d7,0xe0c0-0xe0c3,0xe0b0-0xe0b7,0xe0a0-0xe0a3,0xe040-0xe05f mem 0xdf762000-0xdf7627ff irq 19 at device 23.0 on pci0
ahci2: AHCI v1.30 with 4 3Gbps ports, Port Multiplier not supported
ahcich10: <AHCI channel> at channel 0 on ahci2
ahcich11: <AHCI channel> at channel 1 on ahci2
ahcich12: <AHCI channel> at channel 2 on ahci2
ahcich13: <AHCI channel> at channel 3 on ahci2
ahci3: <Intel Avoton AHCI SATA controller> port 0xe090-0xe097,0xe080-0xe083,0xe070-0xe077,0xe060-0xe063,0xe020-0xe03f mem 0xdf761000-0xdf7617ff irq 19 at device 24.0 on pci0
ahci3: AHCI v1.30 with 2 6Gbps ports, Port Multiplier not supported
ahcich14: <AHCI channel> at channel 0 on ahci3
ahcich15: <AHCI channel> at channel 1 on ahci3
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart2: <16550 or compatible> port 0x248-0x24f irq 3 on acpi0
orm0: <ISA Option ROM> at iomem 0xc0000-0xc7fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: CGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
coretemp4: <CPU On-Die Thermal Sensors> on cpu4
est4: <Enhanced SpeedStep Frequency Control> on cpu4
coretemp5: <CPU On-Die Thermal Sensors> on cpu5
est5: <Enhanced SpeedStep Frequency Control> on cpu5
coretemp6: <CPU On-Die Thermal Sensors> on cpu6
est6: <Enhanced SpeedStep Frequency Control> on cpu6
coretemp7: <CPU On-Die Thermal Sensors> on cpu7
est7: <Enhanced SpeedStep Frequency Control> on cpu7
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
usbus0: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
uhub0: 8 ports with 8 removable, self powered
ugen0.2: <vendor 0x8087> at usbus0
uhub1: <vendor 0x8087 product 0x07db, class 9/0, rev 2.00/0.02, addr 2> on usbus0
uhub1: 4 ports with 4 removable, self powered
ugen0.3: <CP1000PFCLCD> at usbus0
ugen0.4: <ADATA> at usbus0
umass0: <ADATA ADATA USB Flash Drive, class 0/0, rev 2.10/11.00, addr 4> on usbus0
umass0:  SCSI over Bulk-Only; quirks = 0x0100
umass0:17:0:-1: Attached to scbus17
ugen0.5: <American Megatrends Inc.> at usbus0
uhub2: <7-port Hub> on usbus0
uhub2: 5 ports with 5 removable, self powered
ugen0.6: <American Megatrends Inc.> at usbus0
ukbd0: <Keyboard Interface> on usbus0
kbd2 at ukbd0
ums0: <Mouse Interface> on usbus0
ums0: 3 buttons and [Z] coordinates ID=0
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD20EFRX-68EUZN0 82.00A82> ATA-9da0 at umass-sim0 bus 0 scbus17 target 0 lun 0
da0: <ADATA USB Flash Drive 1100> Removable Direct Access SCSI-6 device
da0: Serial Number 14730205323400EF
da0: 40.000MB/s transfers
da0: 14800MB (30310400 512 byte sectors: 255H 63S/T 1886C)
da0: quirks=0x2<NO_6_BYTE>
SATA 3.x device
ada0: Serial Number WD-WCC4MCYPDUY3
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad4
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <WDC WD20EFRX-68EUZN0 80.00A80> ATA-9 SATA 3.x device
ada1: Serial Number WD-WMC4M1219116
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada1: quirks=0x1<4K>
ada1: Previously was known as ad6
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <WDC WD20EFRX-68EUZN0 80.00A80> ATA-9 SATA 3.x device
ada2: Serial Number WD-WMC4M2475126
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada2: quirks=0x1<4K>
ada2: Previously was known as ad8
ada3 at ahcich3 bus 0 scbus3 target 0 lun 0
ada3: <WDC WD20EFRX-68EUZN0 82.00A82> ATA-9 SATA 3.x device
ada3: Serial Number WD-WCC4MHTU34PJ
ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada3: quirks=0x1<4K>
ada3: Previously was known as ad10
ada4 at ahcich4 bus 0 scbus4 target 0 lun 0
ada4: <SAMSUNG HD204UI 1AQ10001> ATA-8 SATA 2.x device
ada4: Serial Number S2H7JD1B305642
ada4: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada4: Command Queueing enabled
ada4: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada4: quirks=0x1<4K>
ada4: Previously was known as ad12
ada5 at ahcich5 bus 0 scbus5 target 0 lun 0
ada5: <SAMSUNG HD204UI 1AQ10001> ATA-8 SATA 2.x device
ada5: Serial Number S2H7JD1ZA18179
ada5: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada5: Command Queueing enabled
ada5: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada5: quirks=0x1<4K>
ada5: Previously was known as ad14
ada6 at ahcich14 bus 0 scbus14 target 0 lun 0
ada6: <WDC WD20EFRX-68EUZN0 82.00A82> ATA-9 SATA 3.x device
ada6: Serial Number WD-WCC4MLXJRKPA
ada6: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada6: Command Queueing enabled
ada6: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada6: quirks=0x1<4K>
ada6: Previously was known as ad32
ada7 at ahcich15 bus 0 scbus15 target 0 lun 0
ada7: <SAMSUNG HD204UI 1AQ10001> ATA-8 SATA 2.x device
ada7: Serial Number S2H7J1PB404164
ada7: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada7: Command Queueing enabled
ada7: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada7: quirks=0x1<4K>
ada7: Previously was known as ad34
pass6 at ahcich9 bus 0 scbus9 target 0 lun 0
pass6: <Marvell Console 1.01> Removable Processor SCSI-0 device
pass6: Serial Number HKDP221516WL
pass6: 150.000MB/s transfers (SATA 1.x, UDMA4, ATAPI 12bytes, PIO 8192bytes)
SMP: AP CPU #2 Launched!
SMP: AP CPU #7 Launched!
SMP: AP CPU #5 Launched!
SMP: AP CPU #6 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #1 Launched!
SMP: AP CPU #4 Launched!
Timecounter "TSC-low" frequency 1200029172 Hz quality 1000
Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-9.3-STABLE-201503270027 []...
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
ipmi0: KCS mode found at io 0xca2 on acpi
ipmi0: IPMI device rev. 1, firmware rev. 0.23, version 2.0
ipmi0: Number of channels 2
ipmi0: Attached watchdog
GEOM_ELI: Device ada7p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI:     Crypto: hardware
GEOM_ELI: Device ada1p1.eli created.
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: Device ada3p1.eli created.
GEOM_ELI: Device ada4p1.eli created.
GEOM_ELI: Device ada5p1.eli created.
GEOM_ELI: Device ada6p1.eli created.
GEOM_ELI: Device ada0p1.eli created.
nfsd: can't register svc name
vboxdrv: fAsync=0 offMin=0x690 offMax=0x14b8
pid 1967 (syslog-ng), uid 0: exited on signal 6 (core dumped)
sysctl kern.geom.disk:
kern.geom.disk.da0.led:
kern.geom.disk.ada0.led:
kern.geom.disk.ada1.led:
kern.geom.disk.ada2.led:
kern.geom.disk.ada3.led:
kern.geom.disk.ada4.led:
kern.geom.disk.ada5.led:
kern.geom.disk.ada6.led:
kern.geom.disk.ada7.led:
Nothing obvious I see. That card isn't going to be compatible with FreeBSD/FreeNAS anyway. So even if it had been detected it still wouldn't work.
MattG
Thanks for taking a look. As for the card, that is weird because others have gotten it to work. Oh well, time to RMA it.
If it worked, it'd be recommended in the stickies.
titan_rw
Not that I'm recommending it, but I have a SIS3132 based card that works on 9.2.0 at least. I still use 9.2.0 as my drive burn-in setup.
pciconf -lv:
siis0@pci0:5:0:0:  class=0x010600 card=0x31321095 chip=0x31321095 rev=0x01 hdr=0x00
  vendor  = 'Silicon Image, Inc.'
  device  = 'SiI 3132 Serial ATA Raid II Controller'
  subclass  = SATA
dmesg:
siis0: <SiI3132 SATA controller> port 0xa000-0xa07f mem 0xf5004000-0xf500407f,0xf5000000-0xf5003fff irq 19 at device 0.0 on pci5
siisch0: <SIIS channel> at channel 0 on siis0
siisch1: <SIIS channel> at channel 1 on siis0
camcontrol devlist: (the only two drives are hooked up to the siis card)
<TOSHIBA MQ01ABF050 AM003M>  at scbus6 target 0 lun 0 (ada0,pass0)
<ST3000DM001-9YN166 CC4H>  at scbus7 target 0 lun 0 (ada1,pass1)
All I use this for is a platform to run badblocks, and smartctl, etc. And for that it works ok.
I have used these particular cards before in an actual zpool, but they were problematic. Wouldn't recommend.
MattG
I would like to thank everybody for their input. I poked around with Google the past few weeks, and made a purchase that seems to be working.
I purchased a PEXESAT322I on Amazon for a decent price. Everything seems to be working fine with it, out of the box, with FreeBSD 9.3-RELEASE-p13. I will post a reply if anything negative comes up, but it seems like a good solution for local backup drives.
http://www.startech.com/Cards-Adapt...SATA-6-Gbps-eSATA-Controller-Card~PEXESAT322I
