Bootpool into normal pool?
Hi everyone,
First of all my appreciation to you guys for helping me. I am pretty new into this NAS and decided to install one after some reading.
I accidently installed trueNAS on 2 hard disks, please seee enclosed.
Now, I want to use ada0 and reset it to a normal disk/pool, something like boot-pool into pool, so that I can use it for storage etc.
Do you know how to do? I tried looking into the forum by searching boot-pool into pool or formatting hard disk, but doesn't really help.
Much appreciated!
You'll need to detach it.
From System | Boot | Actions | Boot Pool Status.
Click the 3 dots next to the disk you want to remove and select detach.
You can then go back in disks and wipe it, then use it as desired.
