Best way to increase pool size
eng
I could not find an answer to a seemingly simple question.
My case:
i have "main" pool with 1 VDEV MIRROR with 2 3TB HDD.
What I want:
Replace both 3TB HDDs with new 8TB HDDs
* I would not like to create a new VDEV
As I understand it, there are two ways to do it.
First way:
1. Replace first HDD
2. Wait for the end of the resilver
3. Replace second HDD
4. Wait for the end of the resilver
5. Make "Expand pool main"
6. enjoy
Second way:
1. in "Pool Status" choose "Extend Vdev"
2. Add both new 8TB HDD
3. Wait for the end of the resilver
4. Detach both old 3TB HDD
6. enjoy
The questions are as follow:
1. Is the second way correct and safe?
2. Is it correct that the first way will take longer (perhaps twice as long) than the second?
3. Maybe there are other ways to do it quickly and correctly?
jgreco
Resident Grinch
Yes, you can replace both disks at the same time. Be sure that both of them resilver completely before making any changes.
It's basically dependent on I/O speed.
You could always make a new pool. Pros: less fragmentation. Cons: lots of screwing around.
  • Like
Reactions: eng
eng
Thank you so much for the quick response!
NickF
My case:
What I want:
First way:
6. enjoy
Second way:
6. enjoy
Option 3 is make a new pool and do a ZFS Send/Receive. It solves the problem @jgreco mentions and you dont have to muck around. :)
Dice
Adding that there is a bit of mucking around, in case there is a lot of configuration dependent on the old pool name.
In essence, once the data is migrated to the new drives, it is a little juggle of exporting / renaming / importing, which allows you to save work on re-adjusting share names etc.
NormanNeu
Second way:
6. enjoy
Instead of detaching both old 3TB HDD I guess they could be left inside and a new pool could be created, right?
NormanNeu
Hi, I am trying now version 1 :
First way:
6. enjoy
I shut down the system. replaced one hdd. booted. now there is no resilvering process starting automatically as I expected. What did I do wrong?
thanks in advance..
NormanNeu
hi, thanks. so i went into storage/pools/pool status, i chose the disk that I want to replace, clicking on the 3 dots, selecting replace, that leads to a popup asking me to specify member disk but as the new disk is not connected there is no option to choose from. soplease, could you give me another hint here? thanks
You didn't tell ZFS that the new drive was supposed to belong to your pool. Disk replacement is done through the GUI, and explained in the docs:
Davvo
If you phisycally replaced one drive with another you should have a new drive there! One of your pools should be in a degraded state.
bal0an
In my case (13.0-U6.1) the replace UI window does not offer any non-member disks to choose from. Obviously the new disk does not belong to the pool yet. I think the dialog window may be broken.
Davvo
Check whether the new drive is properly powered.
