Thanks Davvo. I didn't give enough input on my mussing with that board. I have a new Node 804 on hand and in my research it would be less painful now and later to go Micro than to find a Mini. It took me a minute to figure out what you were suggesting on the Mini and HBA.
Micro ATX, Mini ITX, Supermicro, Node 304, Node 804, X11, X10, E3C236D21, C236, single S models, double S models... I got confused as well and mistakenly read your 804 as 304 (which fit with the ITX size of your now dead MB). It happens.
Given that does anyone se a problem with that board? Or a better suggestion? I have about ten hours now into research and have to say Supermicro sure liked to crank out different models ;-)
They sure do; you should consider the combo X11SSL-F + a cheap HBA (like perch h310,
40 usd although the seller is from china) to see if they come cheaper (you lose out the M.2 slot and 2 SATA ports on the MB). See the following resources.
1) An HBA is a Host Bus Adapter. This is a controller that allows SAS and SATA devices to be attached to, and communicate directly with, a server. RAID controllers typically aggregate several disks into a Virtual Disk abstraction of some sort...
www.truenas.com
This resource was originally created by user: jgreco on the TrueNAS Community Forums Archive. Please DM this account or comment in this thread to claim it. Some time ago, forum frequenter @artlessknave kindly sent me a pair of LSI HBA cards that had failed to work out in a FreeNAS build. Having...
www.truenas.com
That will surely not fit in the node 803.
