So I have a little problem, and although there seems to be some solutions floating around the forums for similar problems - i have not got it to work.
Long story short; All my devices are on the same 192.168.0.X network and the pfSense firewall send traffic to the correct gateway depending on the IP address. Ex; IP 10 will go to Gateway A, IP 27 to C, IP 209 to E etc.
I am trying to get different apps sending traffic to different gateways on my truenas. Currently my 2 nic's are bridged, but i can separate them again and thus get two IPs for the firewall to "read" - but it seems that Apps cannot be assigned to a NIC or a route, it will follow the default anyway? Is there a way to do this? Is there another solution that I do not know about?
Also, can I run several instances of the same app and send one instance to to gateway and the second instance to another gateway?
Thank you very much for any help.
