muzmurray
- Jan 21, 2021
Hello all, I need some advice please as I am a relative TrueNAS newbie. If this explanation is TL;DR please jump to the bottom
I did search on this question before posting, but only found one similar question from 2011 that had no answers, so here goes.....
I have an Intel motherboard based machine that I have been running TrueNAS Core 12 on for quite a while now, this was intended as an experiment, but has now turned into my main storage option. Unfortunately I have been having some reported drive failure problems recently that do not appear to be the actual drives being faulty.
The machine has a Crucial M4 SSD attached to a motherboard SATA port used as the Boot/OS drive, plus 4 x 2TB Seagate Baracuda drives attached as a ZFS pool via a no-name generic PCIe SATA controller. The system randomly shows SMART failure problems and occasional red/write errors degrading the pool and/or faultin a drive. I have tested the drives and they don't appear to be faulty, so I am suspecting the PCIe SATA card is the culprit.
I now realise using a generic chinese PCIe SATA adapter is a big no-no and I have purchased a LSI 9211-4i (reflashed to TI mode) to replace it.
My question is: can I do a direct swap of the different SATA controllers (if I keep the port allocations the same), or will I lose the data and need to completely re-create the ZFS pool?
How does TrueNas/ZFS identify discrete physical drives?
Many thanks,
Muz
Many thanks,
Muz
