jasperwood
- Feb 15, 2022
I am new to TrueNAS and am looking for some advice before setting everything up.
I plan to set this up on an Intel NUC 10 (i7-10710) with 16GB Ram, hardwired to my router.
Currently, I am running a VirtualBox HomeAssistant installation and would like to continue to run off of the same NUC. From what I have read, in order to properly run my USB Zigbee stick, it sounds like I would need to keep this setup outside of TrueNAS. If this isn't the case, that could simplify things.
My thoughts are to run TrueNAS and HomeAssistant as two separate Virtualbox installs (running off of Lubuntu). My current setup of HomeAssistant is using 2 cores and 1024MB of memory so I could dedicate the rest to TrueNAS. Would something like this work or will I end up with issues down the road?
Please let me know your thoughts or if you have any suggestions on a better way to set this up. Thanks!!
